ErikIrvine
- 690
- 865
Is SCORE requiring a 5 lb. fire extinguisher now instead of 2.5 lb.? Also, do you know if SNORE & MORE are as well and enforcing it?
To you guys who are switching to big bottles (5 lb) like you shoulda had this whole time, I have been seeing the mounts used on the 2.5 lb bottles fail. They last a while but eventually they break because of the weight. Then the bottle falls off.
The solution I have Jamie from RaceCo makes for us.
Same concept but stronger and more low profile . $75.00. These are nice but ya have to weld them on. My data sucks today here at the track so I'll load a pic when I get somewhere else. (You might have to remind me)
Then why not have two 2.5 bottles and know they will stay with car than one 5lb and its a crap shoot if its there when you need it makes no sense at all.who comes up with of these rules .and if anything how come on -board systems are not mandatory .who cares about the car on fire i would be more worried about me on fire .most fires are after a huge crash do they think that these 5lb bottles will be there after a huge hit. just my old school opinion
You're right.
Racers should carry only the minimum amount of fire protection on their race car. It was dumb of me to suggest otherwise.
PASSIt doesn’t matter what size they carry if they don’t know how to use it. Without training it’s just added weight. Yes it could help but odds are not stacked in your favor. Just simply having the tool does not increase the chances of it working. This is just my opinion but a class of some sort on how to use an extinguisher would be better than increasing the minimum size. It doesn’t matter how much dry chem is applied to a fire if it isn’t applied properly.
I do commend you on your efforts to increase the safety of others though. That is an admirable action sir.
Thanks.I do commend you on your efforts to increase the safety of others though. That is an admirable action sir.
Just to clarify, As far as I know, extinguishers are rated by U.L. I am not aware of any 5lb extinguisher that will put down a rated 40 square foot agent pattern that successfully extinguishes fire. I believe a 5lb extinguisher is generally a 2A, 10B, C rating from Underwriters Lab. This would be 2 cubic feet of a common class A combustible, 10 square feet of a class B flammable liquid, and will work on a Class C fire without conducting electricity. This is established by doing actual fire extinguishing in the lab with actual results used for the ratings. Unless you have something different, please use the ratings established by the UL for actual real world numbers the public should expect.
