Fire Guys Racing's transformation from 7s to 7200/Class 6 w/ Camburg Suspension
JasonHutter
Apr 5, 2001
3,769
305
Snowmass Village, CO
www.facebook.com
Due to many reason's Paul and I decided to change our truck from 7s to 7200/Class 6. I guess first off we are following the 7200 rules so it will be able to race in either BITD or SCORE with BITD's 85" track width rule. Long story short, we think that 7s has been a great class to race in and could be again but see no progress in the near future for the class so we have decided to move on. We will not be building a new truck, but changing our current truck over to the 7200. So if you are hoping to follow another unlimited budget build you should look in another thread. Paul and I have always been in this for the fun of it! We will continue to have fun going a bit faster and hope to surprise some of the competitors in the class while we are at it! We talked to Jerry at Camburg and even stopped in a couple of times (being from Colorado that actually means something!) before we decided to have them build the kit. Jerry and Jason decided they were up to the challenge and have built something that I believe we will be proud of when we can get it out in the desert! So to start this off, here are a couple of pictures of the truck and the shop in Grand Junction, CO where the transformation will happen.
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
Found this shot, thought it was kind of cool!
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
That is Perry's Fab'n Fiber Tundra one piece front end. I have more pictures of it I'll put up soon. That is the glass that is going on the race truck.
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
Here is the front end kit that we got from Camburg and when I get a chance tonight I'll get more pictures up of the progress and the rear links. This kit would fit '84-'95 2wd chassis I think!?! (with heavy modification!)
Jason
Lance T
Jan 27, 2005
1,311
57
Colorado
Just was in Grand Junction for the weekend. Can't wait to see the build. Wayne building a 7200, you building one, mine sold...Colorado 7s is no more. Ok, well Wayne is too busy to finish his but still.
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
So here are some shots of starting to tear down the truck, cutting off some of the old cage work that will need to be re-done.
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
Starting to set up the arms.
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
So instead of going with anything like the stock lower bushings that we have been running on the 7s. We decided to make our own bushings. The stock ones were a metal sleeve that had a rubber bushing and another metal sleeve inside of it. We decided to scrap that whole thing and take some solid bronze and have to pieces just like the one in the picture slide in from each end with a thicker wall sleeve that is just a few thousands over the total length needed so you can tighten the bolts down tight. Also a picture of some differences to what we ran before. The first being the difference in length on the lower arm, the second is the original stock spindles we used to beef up next to what we are going to, and the last is just the pile of stuff we pulled off the truck!
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
Mounting the arms and starting to see how the new front glass is going to fit!
Jason
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
A few more of the front glass. Also if you notice all the Fox boxes under the rear of the truck we bought 2.5" coil overs all the way around, 3" triple bypass' for the front, and 3.5" 5 tube bypass' for the rear!
Jason
Bajated
Jan 26, 2005
688
78
Long Beach, CA
www.LongBeachRacers.com
Cool, a door slammer class 6 truck will be awesome. I bet you will have the lightest truck out there. What are you doing in the rear? Keeping your 4 cylinder motor?
We bought a chassis platform from Brenthel, we're designing the cage in CAD now. Will be fun to race against you guys again!
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
I can't wait to get out there with you guys again Ted! What is your time line with your chassis?
You have hit the nail on the head with our truck being light. We are doing everything we can to keep it that way. I'll put the weights on here when we get that far. I'm sure if we did a complete build we could be lighter but we have what we have and the budget just didn't allow for us to build from the ground up! As for the back of the truck we were going to leave the frame at first but decided to cut the back half off to accommodate some of our ideas in this build. We are going to keep the 4cyl for now since it has proven to be a reliable engine that is stronger than most stock 6cyl's and we have a plan or two to give it a couple extra ponies! In the rear of the truck we have been running a 22 gal fuel cell that gets us pretty far with the 10mpg that we get at some of the races. We are putting in a 32 gal cell though and moving it up to behind the cab so the difference in weight from full to empty has a little less effect on the overall balance of the truck. The rear will be linked with a 2.5" coil over and a 3.5" 5 tube bypass for tune ability! I'm not saying that we are PPI or Ivan Stewart but we are trying to employ some of their thoughts (I think) into what we are trying to accomplish with this truck. You don't have to have the most HP to get it done, its power to weight ratio's, and the lighter you are the less wear and tear on the equipment!
Here are the links from Camburg!
Jason
wayne_demonja
Jan 4, 2002
267
57
Peyton, Colorado
www.C-FAB.com
Ok, well Wayne is too busy to finish his but still.[/QUOTE]
Hey Lance guess what, I have been working on the new truck just have to make a living first.
Byrdracing
Apr 11, 2009
577
9
Saugus, Ca
Hey Jason, what are you guys doing with the rear end? Keeping what you've got or going wider? Cool build, very inspirational!!!
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
We are going to a wider rear end in it but the extra one is going in the other Toyota sitting behind the race truck in the shop pictures. Hopefully the other Toyota in there gets finished someday, I need it for a prerunner!
Jason
Dezertpilot
Jul 26, 2005
5,704
512
Yuma, Az
The 4.0 toyota motor is plenty strong and reliable, would be a very cool swap. Many trucks have done this swap, to name a couple is the TC 5 lug Yota that is featured here on this site and Dan Vance. Vance runs with the v8 trucks so it is a strong motor. Build looks good though!
charlie_brown
Oct 19, 2002
1,218
69
Yorba Linda Ca
why such big coil carriers? if your running bypasses, just run 2" coil carries. the springs are cheaper and a lot more choices. the coil carrier is not doing anything but carrying the spring.
JasonHutter
Apr 5, 2001
3,769
305
www.facebook.com
No Wendover for us, still in the build phase, and I am heading to California to visit family that week as well.
As for the coil carriers, we thought the same thing and were going to go that route and Fox told us different. We were told by Fox to go with the 2.5" instead. Im pretty sure the parts on the 2.5"s are better than the 2"ers. I also figure Todd at Fox knows the shock business better than me!
Jason
