fuel tanks
boltonbros
Jan 9, 2003
143
hawaii
Visit site
Hey I have a 94' ranger with the 4.0L and I am going to put the broncos fueltank in it. Does the broncos have the same fuel pump, or can I put mine in it. Or is it worth going and buying a fuel cell. Thanks BB
Ryan B
Jun 11, 2003
356
10
sparks nv.
if your going to get go out in the dezert you should deffinately get a fuel cell.
safety first
DSRacing
Mini Metal MOD
Jan 21, 2003
3,486
421
I'm assuming your refering to the Bronco II, if so the actual pumps are different, but the mounting fixtures are the same. When I switched mine, The only thing I needed to do was make a new notch for the alignment tab on the Ranger fuel pump so it would sit flush on the tank itself. The retaining ring and gasket are an identical change over. You may need to lengthen your fuel lines a few inches also.
