H&M 4WD Supercrew Build
desertspeed
Oct 23, 2002
678
345
St George, UT
I spoke with Kevin at length about both options, and since they already have all of their arms set up based around the stock frame it made more sense to do it this way. Unless I wanted to push the motor way back, I couldn't go center mount anyways.
I will have pretty much the same setup as the juggernaut, and quite honestly i don't really want to go as fast as it does
Steering will be a ram assist swing set.
Waitin4dv
Apr 25, 2016
89
61
Wildomar california
Swing steering if that helps. I want to see the setup also. Thought about doing that setup as well in the future. But have no bump steer at all with his setup as is right now. I'm also not a full on desert racer just fire roads here and there.
desertspeed
Oct 23, 2002
678
345
St George, UT
Coming along.....
Waitin4dv
Apr 25, 2016
89
61
Wildomar california
Hey just seeing how the trucks coming and was wondering if this is all I need to attach to my steering box and the blitkrieg steering column mount?
desertspeed
Oct 23, 2002
678
345
St George, UT
That looks like it, as long as the splines are the correct sizes.
No updates on my truck, they have been busy on other projects. Hopefully soon though.
Waitin4dv
Apr 25, 2016
89
61
Wildomar california
How do I know what splines are on the blitkrieg column, and what splines come on the borgenson steering shaft? Or is the spline a common size spline for all steering columns? All the borgenson was says is that it's made to bolt to the fore stock box and steering column.
Mark Newhan
Nov 22, 2005
4,566
2,592
Lakeside, ca.
3/4 - 48 on the Blitz column
Dezertpilot
Jul 26, 2005
5,701
510
Yuma, Az
You cant own a prerunner with the same motor it came with huh lol, looks really good!!!
Dezertpilot
Jul 26, 2005
5,701
510
Yuma, Az
