Heat shield for my header
diirk
599
12
I have an Ecotec powered buggy and need a heatshield for the header.
What's a good way to do this?
Can I weld bungs on the header and mount the shield directly to it?
Or should I have it "floating" above the header, coming off a cross bar or something...that will have to be fabbed.
I also plan to Jethot coat the header and exhaust.
Thanks...
racer56
2,288
479
Just use a good quality header wrap. It is cheap and easy to install. Works great.
diirk
599
12
Well, the header tubes are so close together that I can wrap them individually. I was considering using a header blanket that does all of them.
But, I'm told that wrapping the header weakens it over time.
Wild bill
713
30
Just for a data point.....I rapped my headers on a BBF and the fiberglass turned to glass and fell off in 200 miles. I chipped off the "glass" and used a .060" thick aluminum sheet with 1/8" of fiberglass sandwiched between the two pieces of aluminum sheet. I built some standoffs and mounted the shield about 1/2 from the header to allow some air to flow around. Worked like a charm.
diirk
599
12
How did you mount the heatshield?
Wild bill
713
30
I built some 1/2" tall aluminum spacers and used stainless steel exhaust ties to zip tie the shield to the header.
diirk
599
12
That's a great idea.
scottm
1,867
525
I have used stainless steel foil, aluminum sheet metal shields, and insulation wrap. Stainless foil works well where the tubes are too close to wrap individually. Header wrap is good if you have room, but you want to leave the first 6-8 inches from the head unwrapped. Thats because the tube gets too hot there, which leads to carburizing and embrittlement if its wrapped. Wrap is great for the collectors back to the muffler.
craigincali
535
72
DO NOT wrap them, you will distroy the headers. I unwrapped mine and they are now paper thin and useless.
diirk
599
12
Further research by s@ndm@n and myself gave us this idea...
Using these with SS Hose clamps
with the ThermoTec Micro Louver as a heat shield bolted to the above clamps.
diirk
599
12
Sure thing. It's likely to be a few weeks though.
