Test it in Nevada silt and let us know the results.
What if you put a filter between this and the helmet? It would never get clogged and you'd be assured to get incredibly "clean air"
99.4% in a controlled testing environment using a specific dust coarseness. There shouldn't be any downside to putting a filter on it and If commercial applications determine there's a benefit to running a filter after a centrifuge I'd be surprised if there wasn't also a benefit here.It is 99.4% efficient, so why would you put a filter on it? No need. More dust comes through your shield seal and under your skirt than that. Run 'er.
Following up on this. Anyone have feedback on the system?Anyone run this for the Baja 1000? This was some of the worst silt I have ever seen.
I like to be able to adjust the speed on the pumper. Can you do the same on these?
You can put an electronic speed control on anything with a motor.
Not to mention there'd be some pretty easy way to relieve pressure after the centrifuge to reduce flow into the helmet.The question though is if you slow down the fan does it still produce enough centrifugal force to fling the dust out so the air is clean.
you can milk anything with nipples.... lol
I was wondering how the air filter worked on the Trophylite at Parker?I’ll have one on our truck (Trophylite 6013) at Parker ... will let everyone know how it goes.
So glad someone in the world gives a honest review! Normally it would have been....."It worked amazing!" lolWith everything else we had to do to the truck we didn’t have time to put it on. Wouldn’t have mattered though, Parker had basically zero dust.
We ran good, got up to 3rd place then the pinion decided to leave the third member just after pit 2 on the 3rd lap. Urgh!
—John
Where do most guys put the intake? How would this be different than a traditional parker pumper? Seems that they would be the same.So what happens to the centrifuge fan when the front tire kicks up, or the vehicle in front of you roosts massive quantities of fine to medium sand directly into the intake of the particle separator? Does all this sand then pass through (or need to pass through) the centrifuge fan to fully and completely exit the unit?
