The_Punisher
- 13
- 2
Hello! Hoping to improve "high speed" performance of this rig. 30-60 mph range. Didn't see how the forum was organized, told to move my thread to the appropriate "shop" section.
Here are some pictures. I try to show my bumps front and rear.
Bump stops are eibach shock shaft bumps on the fox 2.0's, and then some sumo springs (originally meant for a JK). They actually "stroke" 2 inches and so do the shock shaft bumps.
1997 XJ
-HP D44/9" 5.13's detroit/true trac
-4.7L Very high strung stroker, solid cam, 11.3:1 compression (tuned and running strong!)
-AW4 with transgo kit and winters shifter+rad designs full manual electronic control
-2800 stall converter
-33x10.50 toyos
-fox 2.0 remote res tuned by accutune offroad
-metal cloak front dual rate coils and deaver rear leafs
-12" travel front and rear
-Front stretch 1.5", rear 1" (104" wheelbase)
- 3 link front (stock jeep setup missing 1 upper control arm. arms are 3" longer than stock. RE drop brackets. Axle is pushed forward 1.5". I relocated mounting points slightly to get the other 1.5" of control arm length, everything is stronger than stock and is working well)
Jeep is 3,900 lbs, 50/50 weight distribution. It's closer to 4,000 and 49/51 when ready to wheel.
I'm running the metal cloak coils because my deaver coils would unseat about 2" at full droop hanging on the straps. I also didn't feel like I needed as much spring rate as the jeep speed guys because my rig is not as heavy. I'm probably wrong. I am happy so far with the metal cloak dual rate coils.
SO! My question for you smart dudes is what would be your #1 change to pick up a little MPH or improve the ride offroad? What would be the 2nd?
My ideas and line of thinking: (1) A bigger tire (2) Hydro bumps (3) 2.5" shocks (but shock fade is not the issue so I don't think this would have an affect) (4) More travel? (5) Front coilovers
Not the best video because I wasn't going that fast. Long day on a trail and the wife and I wanted one quick clip of it because we didn't have any.
1997 XJ
-33x10.50 toyos
