On Topic Help with sand rail suspension info
Brighterside
I am looking to buy a sand rail. I know a-arm is the way to go, but I have seen some straight beams with big shock towers with 12" of travel. How would something like that go through the woops?
Sent from my iPad using race-deZert mobile app
MattV
404
56
Beam cars do just fine if they are set up properly. It's like anything else.. A properly built beam set up will do better than a poorly built A-arm. The amount of travel you end up with is only part of the equation. Things like bump steer (or preferably the lack of it) and how much downward travel vs. upward travel you have available are important, too. I've seen plenty of cars with lots of travel, but if your frame is 2 inches underground at full bump, it isn't helpful.
isdtbower
286
175
12" might be minimal where the dunes get torn up on busy weekends. And probably stunt your fun in the permanent whoops. Utv's are in the 20" range now.
