Housing alignment bushings
philofab
Powered by Optima
Jun 13, 2006
1,921
407
JRod's livingroom.
Does anyone make off the shelf axle alignment bushings for 9" housings or do I need to have someone make them for me? I need to weld some new ends on a housing.
maxyedor
Mar 11, 2007
397
22
Thousand Oaks
Mittler Brothers has what you need http://www.mittlerbros.com/index.ph...nd-narrowing-kits/rear-end-narrowing-kit.html
Any monkey that's halfway decent on a lathe can make the pucks pretty fast, getting the alignment bar can be tricky, if you have an industrial scrap-yard near by, you mite be able to find a very long hydraulic ram to rob a shaft out of, they make perfect alignment bars, if you can find the right one.
philofab
Powered by Optima
Jun 13, 2006
1,921
407
JRod's livingroom.
I think I'll find a lathe I can use and make my own. $525 is a bit steep for how often I use it.
That's a good idea on the ram. I was just going to buy a thick wall piece of DOM. 60" is way too long. It only needs to be long enough to reach the farthest bearing on the center section. Maybe 40-45" for a wide off road housing.
atomicjoe23
Feb 2, 2008
4,058
73
Silverdale, WA
Just looked at the Mittler Bros. narrowing kit and they are using turned, ground, and polished bar stock (TG&P) which you can buy direct from the metal suppliers so there is no need to do any machine work on it after it comes in. . .we use TG&P occasionally here at our shop when we have nominal dimensions that don't have tolerances tighter than +/-0.005".
For an 1 1/2" x 60" piece of 4140 TG&P (heat treated to and guaranteed to +0.000"/-0.001") it costs about $93 not including shipping and handling. . .so are the little pucks that Mittler sells you worth $400 additional dollars. . .guess it depends on how often you are going to use it and what type of machining/machinist you have at your disposal.
maxyedor
Mar 11, 2007
397
22
Thousand Oaks
I wouldn't use DOM, unless you can have it ground prior to use. It's never straight, it's really close, but if I roll a piece on the granite table, I can always find "big" bends in it.
long alignment bars are nice for a fixture, you clamp both ends into some pillow blocks and you can rotate the housing while you work.
atomicjoe23
Feb 2, 2008
4,058
73
Silverdale, WA
Plus the additional cost of the TG&P is minimal over the cost of 0.250" wall tubing. . .the last batch of 0.250" wall tubing I bought cost about $15/ft. . .the price I found for the TG&P is $18/ft. . .it's expensive, but it's ready to go. . .as soon as it shows up on your doorstep.
