Installation cost?
SJP12
Feb 25, 2002
50
SGV the \"626\"
Getting some Fabtech 31/2" lift spindales and extended brake lines on my 2001 S-10, what would be a ball park price for the install i'd be expecting to pay?
I LIVE MY LIFE 1 SET OF WHOOPS AT A TIME!!!
WFODAN
Apr 2, 2001
1,937
126
Huntington Beach CA
www.chaosfab.com
I say go for it yourself . I did my roomates truck for him a while ago and it only took me like 3 hours total to do the job myself . I wasn't working on it too hard either . With that in mind just ask around and figure a few hours labor time from a shop . Hope that helps .
Dan Vance
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
most shops charge around 65 bucks and hour. I'd expect them to charge anywhere from 1 hundred to two hundred bucks. I would do it your self most bolt on kits are a peice of cake to install.
SJP12
Feb 25, 2002
50
SGV the \"626\"
What tools would be needed to install a set of lift spindals and change the brake lines?
Tyson
Dec 19, 2001
597
OC, California
www.race-dezert.com
lug wrench for tires,
Jack,
jack stands,
Pickle fork,
possibly a sledge hammer - or at least a hammer
Misc wrenches for getting the calipers off existing spindles.
7/16 or 1/2" wrench for brake lines.
brake fluid,
a friend to help you bleed the lines after
Though when I did the 4" spindles on my Silverado I didn't need to extend the brake lines.
Good luck
Take you time, its not that hard
Look at me, I can fly
Check It</font color=red>
Dec 31, 1969
Are you sure you need to remove the balljoints. Dont the balljoints stay in the control arms and the new spindle slips in or am i missing something?
Dec 31, 1969
I know that but dont the ball joints just simply drop into the spindle? The ball joints are part of the control arms and you only need a ball joint seprator tool if you are taking the ball joints off the control arms. right? Am i stil missing something?
AZmiik
Jul 8, 2001
288
Yuma, AZ
The wedging action of the ball joint shaft has been known not to just slip off. Most of the time it takes a remover or a pickle fork and some cussing.
Mike
redline
Oct 1, 2001
983
546
Palm Springs
all it takes to remove the spindle from the ball joints on a s10 is a couple of hits of the hammer to the spindle where the bj goes into it (DO NOT HIT THE BJ!) and wah lah off comes the spindle. just putting spindles and brake lines on really shouldn't take more than 2 hours.
dunerking
Dec 30, 2002
309
Shadow Hills,Ca
Well I think they are talking about the tie rods for your steering.You will have to remove those unless you have some fly-by-wire set up.
hit it hard
jarreptolson
May 15, 2001
152
remember to support the lower arm with the jack when using the pickle fork or else you are in for a little suprise
00TRDTaco
Jan 14, 2003
16
Make sure the brake lines you got are the correct ones. When I had my sonoma lifted, the shop that installed the lift (Xtreme Image) made their own brake lines. I sold my truck a while ago, so I can't really remember why, but I think the banjo fitting on the Fabtech lines are incorrect.
ACID_RAIN28
Oct 25, 2002
1,409
60
Temecula, Ca
www.pfluegerracing.com
Most of the time with s-10 spindles you need to notch the caliper to use the brake lines and so that they do not pinch on the arm when it turns, that is probably all they did.
"There are a lot of people hoping I fail. But I like that. I need to be hated."
00TRDTaco
Jan 14, 2003
16
There you go, i knew it was something like that, but I couldn't remember. But I know for a fact that they didn't do that, because I had to wait an extra day to get my truck back because of it. They normally stocked the lines, but they had ran out for my truck, and the shop that made them was closed.
