Intake Manifold help
Steve_HKmtrsprts
Apr 3, 2001
1,252
Huntington Beach, Ca.
www.xyzproductions.com
I have a 95 F-150 with a stock 302. I need a new lower manifold. I called Ford and they want $580 for the upper and lower. Edelbrock has a street legal performance one for about $500. I was wondering are there any other options that I can go with besides those 2 or a used one from a junk yard. Are the ones that they make for the Mustangs compatible with the truck injection. Any insight would help. Also would I have to run a performance injection system right off the bat. I dont have the money to do both, I just want to know for future reference. I just need to get it running cause getting rides everywhere is starting to suck. Thanks!!!
The Edelbrock one:
<A target="_blank" HREF=http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3864&prmenbr=361>http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3864&prmenbr=361</A>
Ryno
Sep 24, 2001
1,230
33
Yucaipa, CA
Steve-
Call Summit...1800-230-3030. They will have many options for you, BBK, Granatelli, etc. I believe the lower manifold is the same for both motors. The mustangs just run a higher # injector and different ignition/ fuel curves. Other than them....JBA in San Diego...they are 5.0 gods.
Ryno
motoxscott
Feb 5, 2002
1,240
299
Huntington Beach, CA (SoCal)
Steve, the trucks upper intake have a twin barrel throttle body where the mustangs have a single. I'm planning on running Edelbrocks intake on a 5.8L. I've heard pretty good things about it.
Feb 19, 2002
6,723
1,554
Easton, KS
The edelbrock 5.8 manifold is great, just expensive. The only issues I had with it were the stock air temp sensor wont fit in the hole unlees you grind away on the manifold or the temp sensor. The 61MM throtle body needs some serious port matching to work right.
Mike_HKmtrsprts
May 3, 2001
722
Murrieta
I say burn it and buy a chevy.... :)
everyone thinks they are superman when the camera is pointed at them...untill they land!!!
Sep 17, 2001
Here
Both of you are gonna luv the emblem I just put on the Sub's grill in place of the bowtie......
Well, maybe not.
