John Baker motors...need some help
Fire1998
238
301
Hey guys.....Ive got a John Baker built Mitsubishi 2.6 motor in my race truck. Its stamped on front of head with Baker 006. We knew motor was from stock but just found this stamp after taking valve cover to check clearances with my buddy. Everything is hand etched with writing on top end. Camshaft says Engel, hand etched, and .295. Dipstick says "J Baker 7 quarts dyno only". We measured compression and we got 12.5 to 1 after math. I'll let ya look at pics and see whats going on. Anyone know...or know someone...who might have any info on these builds? We broke the tip off #1 sparkplug in Parker and now lost about 30 psi in # 1 cylinder compared to 165-170 in 2, 3 and 4. Did a leak down test and it looks like we knicked a valve!!! Bummer. Motor only has 400 miles on it. Any questions or have any info?? I have more pics of camshaft and markings
Fire1998
238
301
The truck. Oh motor was new iwhen I picked truck up. It was in storage for roughly 15 20 years. Oh and everything is marked 006 in valve train.
Bredbaker
111
99
All of John's engines were built by Keith Black Racing Engines, they did Walker's and Rod Hall's too, must have been a factory arranged deal. Originally Class 7 had a 2.4 liter engine limit so the engines were sleeved down to that limit. So maybe if Keith Black's company is still around they may have specs.
Fire1998
238
301
Thanks! As far as I know Keith Blacks shop is shut down. Man....sad all that history dissapeared!! Heres some pics from yesterday after removing head.
Fire1998
238
301
Thanks! As far as I know Keith Blacks shop is shut down. Man....sad all that history dissapeared!! Heres some pics from yesterday after removing head. Intake valves are huge? Valves are Titanium. Intake is ported and polished. #2 cylinder has some scores on cylinder so motor is coming out. Pretty cool history here!!
Bro_Gill
13,812
9,017
Tapered valve guide and reduce shank/stepped, valve stems. All high dollar stuff to do for a motor like that, especially back then.
Fire1998
238
301
Yep...spoke to a dude today in Cali who worked with John. This is a one off motor that can't be replicated today. He said he thinks there were 8 made and I have #006. All parts were factory specs and paid for by Mitsubishi. The head is where all the power comes from and he cant replicate it or will he work on it. Titanium huge valves, Titanium springs, one off cam, billet rocker arm followers and rocker arms. I am basically screwed. Head looks good but do have some scoring in Cylinder #2 from a broke spark plug. Pistons are one off high dome high compression pistons. Block is one off and uses some hybrid block and timing cover. Pistons, crank, head, block oil pan and everything else in motor is one off. He said even if I had an unlimited budget...he wouldn't be able to replicate. Looks like I may have an expensive glass coffee table. Most NA power he can out of a built 2.6 is 220 HP and thats pushing it. Any other motor ideas for this 87 Dodge D50. Its a huge bummer...just spent 10k to have a built C4 transmission adapted to the truck in December last year. Works awesome for the 26 miles I drove it. Do you guys have any suggestions for a Dodge motor for race truck??
This Pistol Petes ex class 3 truck. We' spent 35 k updating truck and now engine has a problem. Looking for any other options to install in this truck that will fit Jeepspeed rules.
Thanks dudes!!
8,414
4,862
i was under impression JS can run Any thing in one of there catagorys as long as its a jeep/ AMC/ Chrysler body, Clive Skilton will help you out, jeepspeed.com, put eng in a museum
TRichards
1,060
367
Talk to Dana Dague. He has a Rod Hall D50 truck. might have some info on that motor. or maybe try to wedge in a straight 6 out of a cherokee. Good luck. Back in the day i had a Iron Duke 4 cylinder that has a lot of unobitanium parts. i feel your pain.
Bro_Gill
13,812
9,017
Look at something a little newer from Mitsubishi. Talk to some of the rice burner crowd about what the Evo guys run. May bolt right up to your trans adapter and modern stuff will make good hp without being wahzoo cast wise and run on premium unleaded. 200hp should be easy with a modern 4 cylinder motor from Mitsubishi.
8,414
4,862
at least 200 pump gas na horses in todays ' tuner' world, thats the way to go, & im sure aa has an adaptor.had to ad,this, ; just put a Big turbo on it.....tooo fast & sillyous.....
Michael Cohen
49
39
Thanks dudes!!
Thanks for sharing the details of your journey. Sorry to hear of the predicament though. I have messaged a frined who has deep roots with Mitsubishi Motorsports and sent him a link to this thread. If he can help, I am sure he will chime in. Good luck and keep on keeping on! Michael Cohen
Bro_Gill
13,812
9,017
Find a different “guy”. I can’t see any reason that motor can’t be fixed
I don't think it is that it can't be 'fixed', I think it is that so many parts are obsolete in the racing world that the cost to replicate is prohibitive, especially when you can drop in a pump gas modern twin cam variable timed motor and make almost to as much horsepower without the temper mental headaches of a 'race' motor.
8,414
4,862
factory race engines ARE timed explosions, they only had to last the race plus 10 miles, ,,,, next.....
Fire1998
238
301
Welll.....race motor was just rebuilt. If I had gone another 25-50 miles....it would have been toast. Cam chain guide was broke!! If it would have skipped a tooth... that big money one of a kind head would have been destroyed!! Found out this is actually a Factory race built 2.8 motor...not a 2.6 which is stock displacement. Head, crank, custom rods and pistons were still good....which were all the custom big money non replaceable parts. Engine guys made custom rings, crank bearings, pin bearings, valve seats and guides and alot more to get this motor back to new. All the important factory one off parts were still good. Should be hitting that 300 HP mark!! Now I have to remember how it came out and put it back together!!!
