Ktm front brake
jmccurdy7
Nov 15, 2007
Chico ca
I have 2004 ktm 105sx and since i have had it never been able to bleed front brake. I took it to the shop and they did but it didnt work great. Recently got new brake line and a new piston for the front master cylinder. Wont bleed the regular way but used a vacuum kit and it kinda started. Then teflon taped the bleed screw. Started working and building pressure but leaking slowly from caliper. I think its the bleed screw but I cant be sure. Is it the whole caliper? Ugh...what next?
kenaroo
Dec 6, 2006
575
69
Austin, TX
  • rebuild the master cylinder with new plunger
  • Rebuild the caliper.. there are o-rings or seals around the piston that might be wore out.
you can order these on line or get them at your local ktm shop
