Leadnav question 2 bluetooth item
TrophyBurro
118
79
Hi guys. Can anyone tell me if an IPAD mini 4 can connect to the bluetooth antenna and the Rugged Radios bluetooth intercom at the same time?
D10R10717
31
37
Contact Rugged or Lead Nav. We use the Ipad Mini 4 with a long AUX cord plugged into Rugged intercom. The less blue tooth stuff running helps the ipad run faster it seems like. My 2 cents.
Zambo
4,427
2,282
Only problem with the cable is that most of the time if you are charging the ipad/iphone you'll get a ground loop through the cable which causes a lot of squeal. I think BT is a better way to connect as far as sound quality goes. Or perhaps if the device needs charging you could use a battery pack instead of vehicle power, haven't tried that method so not sure.
