leafspring shackle question
mpower
Mar 23, 2008
298
13
yorba linda , ca
ok , heres my question to all the leafspring gurus.
whats better? shackle over spring
or
shackle under spring
whats the benefits of each , pro's, con's , strength , ect.
im going to go sua on my truck and in oem form the shackle sits below the leafspring, rather unconventional to what i see on MOST of the leafsprung trucks out there. should i keep with the current design princeable , or change it to shackle over spring and why.
ive read a few books , searched all over the place and came up with the same questions . hoping the talent here can help me out
Captain Air Time
Oct 4, 2005
89
Campbell River BC Canada
I've never been able to feel the difference, but my brain insists that a shackle in tension (under) will be more stable than one in compression (above). Packaging and ride height also play a role. As for strength, a compression shackle can be mounted directy below the frame very easily (strong), with the pivot through, over, or under the frame member. in tension, unless the chassis is very tall, you generally are outboard of the frame(requires more bracketry). What fits seems more important, IME. Every time I contemplate changing to a different shackle, I end up drawing a 4-Link, which doesn't fit either :D
Triaged
Nov 25, 2003
451
16
SoCal LA/OC border
...shackle over spring or shackle under spring...
The major difference is in the installed spring rate. Tension shackle will get stiffer in bump than compression shackle. As with everything leaf spring it is a bit more art than science. If you really need it I might be able to scan the page from the book for you.
Armistice
Jan 10, 2006
449
21
Corona, CA
profile.myspace.com
Over you can get a longer shackle, 12", under, I think you're limited to 9"... but really depends I think. I'm doing a 12" over on my Tacoma when I get to it
mpower
Mar 23, 2008
298
13
yorba linda , ca
thanks that would be great , what book is it. theres not much on leafspring setups in some of the books i got
i like the fact that springrate increases with bump but does it have any drawback to how the spring rebounds in comparison to a compression shackle?
i guess next q would be how to properly setup a tension shackle? ive seen many posts on compression shackle setup but none on tension shackles
atomicjoe23
Feb 2, 2008
4,058
72
Silverdale, WA
Would it be possible for any of you guys to post up any pic's of these two types of shackles??? I'm not really sure that I know what you are talking about. . .I'm no leaf spring guru, but I didn't even know there were different types of shackles (other than what you see on the rock crawlers and general off-roaders. . .i.e. boomerang, reverse, extended, tow shackles, etc. . .)
Thanks!
Triaged
Nov 25, 2003
451
16
SoCal LA/OC border
SoDrty
Jan 15, 2006
25
Costa Mesa, Ca
here's a copy of some of my notes re: leafspring setups, not sure if this will help you out or not..
