LOSI Baja Rey Offroad truck
Check out the new Losi Baja Rey
Well look what we have here, it is a real Baja in 10th scale by Losi! This is a complete new design with a very long travel and independent shocks, four link live rear axle to beat the terrain with ease! This will be a new standard in 10th scale off-road racing. Available in 2 color schemes this brushless beast is the must have bash car for this summer!
Features
◼︎ Realistic, Baja-inspired chassis design ◼︎ 3mm hard-anodized aluminum chassis plate ◼︎ Integrated chassis roll cage ◼︎ Dynamite 3800Kv brushless power system ◼︎ Spektrum™ AVC® technology ◼︎ Long-travel suspension 4-link live rear axle ◼︎ Waterproof electronics ◼︎ Sealed, metal-gear transmission and diffs ◼︎ Coil-over, oil-filled shocks ◼︎ Easy-access battery compartment ◼︎ Functional spare tire mounted on roll cage ◼︎ 4-piece, bolt-on body panels ◼︎ Includes Spektrum DX2E transmitter with AVC adjustment
Action!!!
Specifications
Type: 4WD Desert Truck
Completion: Ready To Run
Scale: 1/10th
Length: 540mm (21.6 in)
Width: 320mm (12.6 in)
Height: 190mm (7.6 in)
Weight: 2.8 kg (6.1 lb)
Ground Clearance: 55mm (2.2 in)
Wheelbase: 370mm (14.6 in)
Chassis: 3mm Aluminium
Suspension: Independent Front 4-Link Rear
Shock Type: Coil Over, Oil Filled
Drivetrain: 4WD
Differentials: Bevel Front/Locked Rear, Both Sealed
Wheel Type: TT 2.3
Tyre Tread: Desert Claws
Motor Type: Non-Sensored Brushless Motor Size: 550
Pinion: 13T Gear
Pitch: Mod 1 Internal Gear Ratio: 3.8:1
Final Drive Ratio: 10.99:1
Brakes: Controlled via Motor/ESC
Body: 4-Piece Screened Ball Bearings: Full Set
Experience Level: Beginner
Environment: All-Terrain
Assembly Required: No
Availability and pricing
The 1/10 Losi Baja Rey 4WD Desert Truck is available around end of June. Pricing will be $449.99 for USA and €519.99 in Europe.
Direct links to models:
Red model: 1/10 Baja Rey 4WD RTR Desert Truck with AVC®, Red | HorizonHobby
Blue model: 1/10 Baja Rey 4WD RTR Desert Truck with AVC®, Blue | HorizonHobby
sb4pro
3,800
3,090
If I didn't already have the Axial Idve gotten this one . I shoulda waited . :( It actually looks even more scale
( if that's possible ) than the Axial .
