Ls3 intake flip
Slippery P
Dec 8, 2007
2,956
3,604
Valley Center CA.
whats needed to flip the intake manifold to face the rear ?
You will need to cut the factory oil pressure port off of the valley cover and plug the hole with an NPT plug then relocate the oil pressure sensor, also will need to grind some of the honey comb down in the under side of the intake near the throttle body end to clear a couple of the factory valley cover bolts.
Slippery P
Dec 8, 2007
2,956
3,604
Valley Center CA.
Yes drill and tap the port to take a 1/4 NPT plug valley cover will have to be removed.
Dec 29, 2004
16,402
3,527
The Cloud
^^^ For use opposite that of its original position. IE: front to rear.
Nino Ficara
Nov 6, 2016
71
57
Joshua Tree
I have a 5.7 2007 hemi n I have same question. Everything on that looks symmetrical, so it looks like it could be mounted either way? Anyone know?
