Mass Air Sensor?
Bajatoy
Mar 10, 2003
51
Surprise, AZ
In my last trip to the desert, I ended up running over my mass air sensor.(Long Story) Any ways, I put it back on my truck and it still would not run. So to trouble shoot the MAS I put it on my friends toyota. It ran for about 5 seconds then died. Problem solved I know the problem for sure. But now his truck wont run after I put the working air sensor on. The engine is getting spark but just wont run now. Any ideas or thoughts on what I did wrong?
Any help is appreciated.
Mike_HKmtrsprts
May 3, 2001
722
Murrieta
check all the connections you took off when my MAS when bad on my chevy it was just hard to start and idled rough I doubt you messed up his truck by putting on your MAS sounds like you might have broke a wire some where and just over looked it??....Mike
DuffcoDan
Dec 5, 2001
75
Brea, CA
try removing the EFI fuse (under hood, near the battery) out and replace it after 10-15 seconds. this will reset the computer.
Bajatoy
Mar 10, 2003
51
Surprise, AZ
Hey they thanks for the help. I removed the fuses and no luck! After a few curses and a couple beers I found another EFI fuse under the dash that was blown down by the hood latch!
Thanks for the help!
