master disconnect switches
arqangel67
1,761
149
does anybody know where i can find those big master disconnect switches found on car haulers ? they are about 4 inches in diameter and look sorta like a dial . any help is appreciated
DSRacing
Mini Metal MOD
3,471
394
arqangel67
1,761
149
those look pretty close and probably the same thing . Thanx guys! Are these switches able to swtch between 2 differnt batteries?
arqangel67
1,761
149
chec ked links and they do. Thanx again !!!
9Iron
763
39
Got mine at NAPA... two kinds: regular and marine.
I assume the marine one is water proof to some point.
Went with the regular one and mounted it in the cab to select
between either, both or no battery position.
pre-ran with it, so far so good.
Use number one cables, boot it as you go through any firewall or floor-boards.
have fun!
arqangel67
1,761
149
Thanks, that's exactly where i had planned on mounting it. Also planed on relocating battery and adding another .
Mike_Cohen
440
58
Hi Guys!
We stock a wide variety of Mil Spec and USCG electrical products including Master Battery Disconnect Switches: http://www.racerxms.com/Battery_Cut_Off_Switches.html
I believe you are looking for a Cole Heree, Hella, or Perko style, they kind of look like a claymore mine. Be careful where you mount them as we have found that the Cole Heree unit, over some time, will lose the detent / locking positions if the back of the switch is placed in an open exposed area.
Take a look at the Blue Sea Switches. They are small and compact yet pack a great punch for value and can be flush or surface mounted.
Please feel free to call or e-mail me with any questions.
Good Luck!
Mike
arqangel67
1,761
149
thanx, message sent good selection of products
