you will find the pats on all ford's from 98 and up,. but,. we were told that there are some ecu's that can be used on this engine and come without the pats, TZT0, thats the code of that ecu,. you don't need to reprogram that ecu to be used, well, we just went through all that, it was not easy but it was worth it at the end,. we bought a 98 sohc engine with original wiring harness and ecu, not all ecu work well to be reprogramed, some that worked for us, CDE3 and, shi.. forgot the others, but that one works great with a chip,. juanco did the chip,. i mean, he reprogramed our ecu,. with that he disables everything that you don't need on a non street legal engine, ha,. so. we are racing this engine with a ford c4 trans, we had that same transmission with the ohv, to use the sohc on the same transmission just need to custom made the flywheel and use the sohc flexplate,
so,. from 98 to 03 are ok, newer= less mileage and other little things,. so,. buy it with all the wiring harness, well, at least with main power distribution box or fuse box,. from there to the engine , they come with 4 oxygen sensor, you WILL NEED just 2 of them,. the wiring is preatty easy to make,. let me find the thread that i opend when we first started the swap,. good luck,
we have learn a lot on this engine, so, you are in the right place to ask,.
