More Lift on my '98 F-150
Waldo
Safehouse
May 15, 2001
5,455
122
Ladera Ranch, CA
www.facebook.com
More Lift on my \'98 F-150
I have a '98 Ford F-150 w/Camburg a-arms, ball joints, Eibach spings, Bilstein 5100 shocks.
Anyone know if I can or how to raise the front end a little bit more without adding spindles? The front is not quite even with the back end. It is not a performance problem, just looks. The suspension works great for what I do with it. Thanks!
BRAAAAAAAAP!
Tyson
Dec 19, 2001
597
OC, California
www.race-dezert.com
Re: More Lift on my \'98 F-150
Well, I would suggest just getting the spindles seeing as how you like the way it currently rides. Anything else you do may make it stiffer. Just my .02
Laterz
Mike_HKmtrsprts
May 3, 2001
722
Murrieta
does your trucks x-cab doors both open or only the passenger side? if not get a coil spring for a 01' they spring rate might be stiffer because of have 2 rear doors but ask Jerry for sure other than that you will have to step up too spindles. or maybe some air shocks up front?? J/K
mustafa
Apr 1, 2001
885
40
La Verne, CA
Put more air in the front tires.
He who lives by the sword, gets shot by those who don't.
Waldo
Safehouse
May 15, 2001
5,455
122
Ladera Ranch, CA
www.facebook.com
I didn't think about the air in the tires...Wow! I put 75psi in the front and dropped the rears down to 15psi. It looks bitchen now! J/K.
What does the 1 or 2 door have to do with it? Weight?
I thought about stiffer springs but I don't want the a-arms to sit on the bump stop. I guess I'll just leave it and put a spring in it next time I get new tires. I already knew the answer but wanted to see if anyone had any wiz-bang ideas! Thanks for the time.
BRAAAAAAAAP!
John Bitting
Administrator
Apr 10, 2001
11,951
2,561
Rancho Santa Margarita
race-dezert.com
go to a 35" tire in the front and a 30 in the rear. Should do the trick and you will be able to burnout killer too.
A man is not finished when he is defeated,
he is finished when he quits.
-- Richard M. Nixon
Dec 31, 1969
What have you done to the back? If you have put a leaf pack did you flip your hanger/shackles?
www.offroadrangers.com]
Jun 18, 2001
299
F150s come flipped.
<A target="_blank" HREF=http://www.animalhousedesigns.net>Animal House</A>
Dec 31, 1969
Camburg does offer spring spacers for the Ranger kits, they may also offer the same for the F-150. I had the same problem with my ranger after I put there extreme 4 wheel drive kit on my truck. It also had Nationals in the back. It sat kind of stink bug for a while. Jerry mentioned that these spacers could be bought to raise the front a little more. Eventually the springs settled in the rear so I didn't have to do the spacers. Look into it.
-Josh
<A target="_blank" HREF=http://www.JTB-Design.com>www.JTB-Design.com</A>
