Need Buggy Steering advice
1992f150
Dec 23, 2001
373
Azusa, Shame of the foothills
www.y2khai.com
Ok so I'm trying to get the steering done on my buggy, the problem is the shaft is too low and hits my foot if I try to use the brake pedal. I cannot just raise it up because then the shaft hits the underside of the frame tubing, as you can see in the pictures (the cluster of 1" tubing behind the rack and pinion).
So now I am looking for ideas on how to fix this problem. I've tried looking at it from every different way, the only thing I could come up with is cutting off the frame tubing and building it up again in a different spot.
Thanks in advance
P.S. The frame is a chenowth 4wld. Oh yea don't worry the wood floor is just for mocking up the pedals so I have a place to rest my feet when I check for fit.
MNotary
Apr 25, 2001
929
16
Melbourne, Fl
The angle of the rack mount correct?
Move the seat/pedals/steering wheel back and change the angle of the steering wheel.
FABRICATOR
Apr 3, 2001
5,146
107
Ventura County, CA
It really looks like just shortening the steering wheel shaft would do the trick. It would move the lower section of the long shaft toward the apex of the tubes where there is more height available. This would raise the long shaft and move it away from the pedals.
1992f150
Dec 23, 2001
373
www.y2khai.com
the short shaft cannot be shortened, only lengthened. The long shaft above the pedals is hitting the frame tubing, and that is as high as it goes. If I shortened the shaft at the wheel then it wouldnt be able to connect to the U-joint.
FABRICATOR
Apr 3, 2001
5,146
107
Ventura County, CA
That steering shaft does not appear to be up in the apex as much as it could be. But if what you say still applies, then the next move would be to lessen the angle of the steering box. It should be pointing at or just above the steering wheel. It looks like it is pointing way above that. The tie rods don't care about the angle, only the height of the rack. Moving the box shaft down just a little would allow you to shorten the steering wheel shaft. This would move the long shaft up and away from the pedal area.
michael_loomis
Jun 27, 2001
26,215
2,427
Temecula, Ca.
careful .... as moving the rack direction will affect the bumpsteer ... although it does look quite high.
Sep 17, 2001
Here
I concur, the angle of the rack's input shaft is too high. Ideally the input and all of the steering shafts will lay in the same tilted semi-horizontal plane. Doing so will reduce the operating angles of the U-J's.
[/ QUOTE ]
Assuming the bump is as correct as a beam car can ever get, rotating the rack about the inner TRE's or SRE's, and not the upper beam tube, will not affect bumpsteer. Means making a new bracket for the rack though.
1992f150
Dec 23, 2001
373
www.y2khai.com
thanks I ended up chopping the rack mount and rotating it as accurately as possible, pointing the steering nub down and keeping the tie rod mount plate in the same spot. I got it tack welded right now, it gained some bumpsteer, about +1.5 at full droop, and +1/2 at full bump. The steering shaft has plenty of clearance now, so it is just a matter of tweaking the rack mount abit then welding it up.
