the two wires off the trans I just tied together i believe they are the ones coming out off the drivers side on the trans and the ones that are connected to it go to the backup lights on the drivers side of the trans mine had a red plastic piece on the trans(backup light). the piece that is connected to the actual clutch I just took part way off pushed the spring down jammed a wrench in it andtaped it up for now. But I was told the pink wires are to be tied together. I am going to get a piece from kritter to bypass it right later this week. This was all on a ranger 5 speed to c4. I assume you have a art carr or winters type shifter and they make a piece so you can hook the nuetral safety wire up to the shifter and it wont start unless ur in park not sure if they have it for the back up light also, going to check this out and get it for mine.
