Need some help from all of you XR400 guys!
UOURacing
May 19, 2006
167
Texarkana, Texas
I am in the process of restoring and rebuilding a 1998 XR400. Everything was going very well untill I was removing the banjo bolt from the oil inlet strainer at the bottom of the frame's downtube. The banjo broke smooth off where hole is drilled across the bolt. Anybody had this happen? If so, how did you get it removed? I purchased a bolt extractor that you tap into the center and turn it out. However it has not made too much progress. I hate to get too crazy and create a bunch of metal shards to get into the lubrication system.
Racer21(Roberto)
Apr 20, 2008
731
31
Pahrump, NV
I wish i could help, but unforteunatly, im only good at riding the XR400. lol. but thumpertalk.com has a whole section dedicated to XR250/400's. so i would check that out if i were you.
UOURacing
May 19, 2006
167
Texarkana, Texas
All good! had to take out the whole oil strainer. A real pain that took an impact wrench. ordered a new strainer, o-ring, washers and banjo bolt. Bike is back together with no leaks! amazing!
