The shocks have almost zero rebound damping and a lot of compression. Enough pressure to make them return. Normally you would have a poly bumpstop mounted to the bottom of the arm so that it doesn't make so much noise when it hits. Slapper arm ends can also be attached to the A-arm itself instead of the frame. Makes figuring out the pivot point a non-issue.
