So I've always run shocks with air bumps or hydraulic bumps, separate from the shock; building a new rig and after a discussion I'm considering a 2.5" King triple bypass shock, since I've been told the third bypass can be configured to serve the purpose of the bump stop.
Basically, shock has its set compression and rebound based on valving / adjustment, but the bypass is configured to firm up at full extension, absorbing the landing. Sounds good in theory, and will help with overall packaging; also sounds strange, and slightly bizarre. Anyone running shocks only, setup this way?
