Oil pressurre sender on 5.0l
indirtwetrust
May 23, 2009
El Cajon, CA
I am trying to put an Autometer Oil pressure sending unit on my 5.0. Idealy I would put it where the stock one is, but the autometer canister is about 2" in diameter so will not fit in the stock location. On the opposite side of the block there is a plug that takes a 1/4" allen, so my question is has anyone had this problem? and if so, is it ok in this port on the passenger side because the canister is kind of large and will stick out quite a bit there and I worry about it breaking off. Or should I try to use a brass 90 degree fitting and try to use the stock location? Please help! any suggestions welcome. Thanks
steveG
Jul 10, 2003
1,962
97
Arroyo Grande, CA
Find the stock extension.
cancinoj
Apr 3, 2007
842
29
TIJUANA B.C.
have seen many race trucks with an hydraulic extension line or high pressure line custom made just like the ones used on any hydraulic system like power steering or brakes, it works the same way many guys install a remote oil filter , you know, a high pressure line then you connect your sender any place you want,. can't find any picture, but that way you can fix that problem.
DSRacing
Mini Metal MOD
Jan 21, 2003
3,503
441
I just went and checked in my garage and I have an extention just like SteveG posted. It's yours if you want it. Send me a PM if you are interested. Attached is a pic of the one I have.
