OIL QUESTION
mustafa
Apr 1, 2001
885
40
La Verne, CA
I have an 01' F250 with a V10 and the manual recommends 5-20 wt. oil. The viscosity is almost the same as water. What would be the advantages/disadvantages of going
to a heavier grade oil? Would my mileage decrease? I do light towing with it (under 3000 lbs.).
He who lives by the sword, gets shot by those who don't.
Jun 18, 2001
299
More drag in the system...lower performance, lower gas mileage, hotter temps, to name a few. I am not sure how dramatic these may be but those are some of the things that could happen.
FABRICATOR
Apr 3, 2001
5,146
108
Ventura County, CA
This can get worse than any shock wars, but it's doubtful we'll hurt any of the oil companies!
Most of the newer vehicles call for very thin, multi viscosity oils. Be careful with changes as some require them for the warranty to remain in effect. Some vehicles actually monitor the condition of the oil through sensors and the computer will tell you when the oil should be changed. Part of it also has to do with mileage and other environmental concerns. Engines are also required to run at higher temperatures these days. Who knows how bad they really need them? The owners manual usually lists several variations for different uses and climates. I wouldn't stray too far.
IDRA_CRB
Apr 3, 2001
1,016
Central Valley, CA
A partner of mine (we used to be mechanics together) is now an instructor for Ford. He sez do not go to a heavier oil. These engines are built to much tighter tolerances than previous versions.
It's quite possible that portions of your engine would not receive proper lubrication if a heavier oil is used.
It's a good idea to carry some with you (especially in Baja and other remote areas) as many retailers do not carry it yet.
Reese
Dec 31, 1969
run 5-20 weight.
-Chris
2000 v6 4x4 TRD 5-Speed Tacoma
