oil question
dezerts10
BANG!! BANG!!
Jan 23, 2002
2,092
147
Temecula, Ca
it might be a dumb question but i dont know the answer so... my s10 manual calls out for specific fluids should i follow the manual to the " T "? like for the transmission in particualr. transmission it says use friction modified synchromesh transmission fluid. also i know tha tthe pink dex cool stuff GM uses isnt to great. i want to change out to the regular green anti freeze/coolant stuff flush the coolant system out and fill it back up. will i be causing problems?
thanks for the help
Gregg
matt_helton
Racer
Feb 16, 2003
3,876
302
Yorba Linda, CA
Visit site
yer right about the trans. ONLY use synchromesh oil. its pretty pricey but that is the oil you SHOULD run. as far as the coolant goes, ditch the dexcool only as long as your factory or extended warranty IS up. not before, unless you dont care about a voided warranty, "should" the unexpected happen.
jeff
Moderator
Apr 1, 2001
7,454
352
California
www.performancelifts.com
DexCool is terrible, TERRIBLE stuff.
Avoid that crap at all costs. I will NOT run that stuff in ANY of my vehicles ever again. A few years ago I had major problems with DexCool and right now there is a pretty good class action suit building against GM because the stuff goes from pretty orange to a sick baby brown in a year or two. Follow this link for more info: http://www.nbc4.tv/automotive/2369813/detail.html
Whatever you do, DON'T RUN DEXCOOL - even if the manual recommends it! The aluminum in your vehicle will live a happier life with the generic green stuff. If you want to see a sample of the DexCool sludge I'd be happy to scrape some out of my radiator for you.
Aloha
Here's the CA suit address: http://www.dexcoolcase.com/
