Pits Base station radio setup
paranoid56
Jun 11, 2008
211
144
Santa Barbara CA
Does anybody have any pics or share some setups they use for a base radio? At the last races i noticed most had 20ft masts with a vhf antenna setup on top. but what are people using for base radios? powering?
Thanks
wrightracing.net
Oct 16, 2005
845
192
www.wrightracing.net
I have built for around 15 or so of these radio setup's for my customers with 110 watt Kenwood Race Radio's, VHF and UHF in ATA Flight cases and in Custom rack mounts. I usually put antenna tuner's in the rack also, so when you get your antenna up at a new pit sight, you can make sure your antenna is tuned perfectly Everytime quickly. And you can monitor your power output on the same meter to make sure the radio is performing properly.
I use a 50ft garage 10g extension cord with 3 conductors. The is a 12 volt radio, so I Cut the ends off. White and Black go to Positive on a Anderson Winch plug and Green goes to negative or ground. Then it plugs into my truck winch plug on front or back. I usually have a small generator keeping the truck battery charged to keep the noise down.
I have used a 20- 35 mast and fiberglass di pole antenna.
With Grey RgRG8x coax.
View attachment 217014View attachment 217016View attachment 217015View attachment 217013View attachment 217012
Jan 17, 2019
10,927
6,611
sandiego
i built one out of an old fiberglass pole prunner, and slid into end of old wind surfboard fiber glass mast, it was cool, , light& strong, and collapsible to stow, hey!, i just remembered, i still have the mast if any one wants it, its 12 14 feet??, i can messure and take pics, free .yup 14 feet, put my good pol prunner for a visual,14 ft extended too,28, overall
wrightracing.net
Oct 16, 2005
845
192
I like using flag poles. The last couple guys I know got something like this on eBay.
It came with a mount that you drive over with your tire.
They telescope out and are easy to setup. Under a $100 with free shipping. Light weight aluminum or I have seen fiberglass, but you don't want something that sways in the wind to much without guild wires.
I have a old military 40ft Hydraulic telescoping aluminum mast, but it is a Beast to transport and only went out on the trailer to races with us.View attachment 217035
calstyl2
May 9, 2013
652
1,106
Cherry Valley, CA
I suspect its the 120v inverter/18 battery that is sold for the 18v line, we did a few boxes like this for Baja but had to be tied to 120v power source
paranoid56
Jun 11, 2008
211
144
Santa Barbara CA
Thats clean as hell, got any internal pics?
This please^^^
Where did you get those female inserts for the batteries? I want some.
Sorry, missed these. dont judge me to hard on the internal pic lol, still want to fix the wiring a bit.
but basically some ryobi battery inserts from ebay/amazon a good victron dc/dc converter (takes the 18v to 12v needed for the radio and usb chargers) some wago wire connectors for easy assembly and a 20amp CB.
I didnt go with the inverter as its not very efficient way to power 12v items.
Crusty Shellback
Dec 7, 2017
613
685
Ventura County
I just use the radio in my truck. Kenwood 110W radio with remote head.
Main radio is mounted under the rear seat. Head unit and speaker can sit in my center console, or be run out the back window and sat on the tailgate. Looking at building a tall mast antenna for when we are at the pits.
When not in use, they store under the back seat in the storage box.
dan200
#BSF200
Aug 28, 2007
16,150
8,632
Tempe, AZ USSA
