prerunner truck transmission
dezerts10
BANG!! BANG!!
Jan 23, 2002
2,095
147
Temecula, Ca
what are truckas like the "luxury/ TT prerunners" using for there transmissions?
I have a mixed feelings about going t400 in my truck cause its only a 3 speed and my plans are to build it then trailer it to baja and drive it everywhere so that means long drives on the highway with a 3 speed thats annoying and reved out as well. I was looking at trememc t 56 transmissions too and they are 6 speeds transmissions which would be good for my needs. 1 2 3 4 inthe dirt 5 and 6 for the long cruising ont he high ways.
is there anythign i could do to a t400 to make it crusie better onthe highway? should i look at a different trans? i dont want anything that requires a computer to operate that is a key factor.
Gregg
Alex Paterson
Jun 30, 2004
2,806
251
Tucson, AZ
apache.secure.mexicaninsuranceonline.com
You can put an overdrive in a TH400 or build a 4L80E (I think thats correct). I have been told the gear options on the 4L80E are not great for offroad and you have to run more gear in the rear but they are doable. The black newer F150 prerunner of Nick Baldwins that was finished last year has a 4L80E in it. Culhane can help you out and has a lot of good information.
Alex
philofab
Powered by Optima
Jun 13, 2006
1,921
407
JRod's livingroom.
My choices would be in the following order:
4L80E
Viperized T-56
T400 w/ gear vender
The T-56 is only second because I like an slushbox in the desert better (I normally prefer manuals in everything else).
dezerts10
BANG!! BANG!!
Jan 23, 2002
2,095
147
Temecula, Ca
still havent gotten to talk to anyone about the trans yet. thanks for the information so far. the t56 i am looking at is from rockland tremec sent me to them. here is the quote i got.
WE BUILD A PERFECT SET UP WITH BELLHOUSING T56 WITH CORVETTE ZO6 GEAR TRAN. ITS THE BEST MONEY CAN BUY. WE STOCK THEM READY TO GO SHIFTER LOCATION IS 25" FROM ENGINE WE SELL A ALUM OR A SFI BELLHOUSING , QUICK RELEASE SLAVE AND REAR 30spl.YOKE FOR THIS TRANS.
TRANS IS RATED 750FTLBS AND THE MAINSHAFT 1000FTLBS OF TORQUE
RATIO 2.97 2.06 1.43 1.00 .084 .056 OR 2.66 1.78 1.30 1.00 .074 .050
TRANS NEW 3495.00
BELLHOUSING ALUM 200.00 (LS1 ONLY) SFI STEEL 465.00 (LS1 & SB/BB)
QUICK RELEASE SLAVE 349.00
30 SPLINE REAR YOKE 169.72
RSG OIL 5QTS 48.90 WE MAKE OUR OWN OIL
SINGLE DISC CLUTCH WITH FLYWHEEL 600.00 EST
TWIN DISC WITH FLYWHEEL 1300.00 EST
nd looking at the trans and the price onthe clutch that is what got me thinking of something else.
dirtdudeaz
Jun 19, 2007
414
12
phoenix, az
finish line transmissions builds these things up pretty good from what I hear. And if you have a gm transmission already you send in your housing and they send you a built one and it is a lot cheaper.
dezerts10
BANG!! BANG!!
Jan 23, 2002
2,095
147
Temecula, Ca
it needs to 100% manual. I do not want to run a stand alone computer system for the trans. I told the engine builder 300 to 350 hp as reliable as possible is what I wanted said its should be doable easily so thats what im looking for
Cerberus2k7
Nov 28, 2008
32
Denver, CO
www.flippedstudio.com
Weight/power is still a bit of an issue, but we ran a LQ9/4l80e non-electronic from Transmission Center with a ratchet shifter in the drag car.
