Question about the "right" steel for cages and suspension
Breth
Apr 20, 2009
41
Switzerland
Hey all!
What steel you guys using when fabricate spindles, upper/lower control arms and bedcages?
I saw a few builts where they using chromoly for the suspension. Thats only because you can built it lighter?
Do somebody use stainless steel? Because cages dont rust then?
Is it because stainless is to expensive or isn`t it strong enought??
Best regards Sascha
Wild bill
Jun 23, 2008
713
30
ponca city, ok
4130N for any suspension component. 4130 is best overall for tensile strength, weldablility, ande fatiguability.
Breth
Apr 20, 2009
41
Switzerland
Thanx for youre answers!
So im looking to built a bedcage with bumper and stuff. So here in europe we have a lot of rain. So thats why im thinking to use stainless-steel, because i dont wanna powdercote the stuff.
I also wanna built some upper controlarms. Do you guys think stainless steel is not strong enough? I dont wanna go hit 40meter Jumps, its more a suspenion-lift.
Regards
westtexasbaja
Mar 6, 2005
568
14
Texas
Regards
FWIW, I've had good luck with Dupli-color's clear primer. Turns the metal black and keeps it from rusting. And you can touch-up areas without having to mask everything off.
ErikShallbetter
Oct 31, 2005
774
89
Minnesota
People don't use stainless because for one reason it is really heavy. Also, if you keep chromoly oiled it does have some rust inhibiting properties. For a bed cage I would use 1.5 in a small truck and 1.75 in a fullsize.
randy68
#1 Enemy of Google
Jan 21, 2009
3,218
3,195
Chino Hills, Cal.
Stainless is too soft (& heavy). It has no "memory." Meaning once
it bends, it stays bent. 4130/4340 is a lot harder/tougher, will bend some before it brakes, and
has a "memory."
Spindles, axles, etc. 300M if you can find it. Basically it's vaccum melted 4130.
