Chris Tobin
- 5,998
- 1,177
The KMC Enduro Beadlocks I am running on my Silverado 2500 HD are in need of powder coating to get them looking decent again after a couple Tennessee winters.
When having a beadlock wheel powder coated do you recommend masking off the inside and outside tire mounting surfaces as well as the lug nut seat and threaded holes? Or simply coat the whole wheel then chase all the threads before installing the hardware. My thought was to mask off the beadlock ring mounting surface on the wheel then maybe even install the old bolts and powder coat with them installed the remove the tape and bolts after it comes out of the oven and cools off.
On the beadlock ring itself do you guys powder coat the entire ring or just the front side? I was thinking to mask the back side so that the rubber from the tire will seat directly on the aluminum not powder paint.
What do you guys think? Am I over thinking it, and should I just worry about masking the threads and coat everything else? I see several race teams with powder coated wheels. What are they doing?
I plan to have the wheels coated gloss black with the rings GM Luxo Blue/Blue Topaz (that's the color I will be painting the truck when it is done) and will be using polished stainless steel ARP 12-point bolts and washers. I think that will be a great looking combination and they should last a long time.
Any suggestions and advice will be greatly appreciated!!!
Thanks in advance,
Chris
Thanks in advance,
Chris
