Questions on Coilovers on Yota
fishd00d
What A Joke
15,548
5,709
Ok well I got my coilovers today. I got some 2.5 12" SAW's. I got dual rate. But I have a few questions.
1. Is it best to run Dual Rate with a 12" shock that will be getting 14" travel or did I just need single rate?
2. Anyone reccomend a spring size? Baja Concepts reccomended 500 over 500 so thats what I went with. Does this sound right for a Toyota Ext. Cab 4WD?
Its gona be a tight fit with the V6 but I think I can do it. I start making the hoops tomorrow and hopefully I can have the front end done by tomorrow because I am suppost to goto the desert Thursday afternoon!
Also I ordered some Downey springs for the back since mine are just about to break! Anyone have any thoughts on the Downey springs? I figured they cant be that bad for $135 for the pair!
Go Big Or Go Home
i have an 88 toyota with a full coil-over front end. it has 12 inch king 2.5s, with duel rate coils, 600 on bottom, 500 on top.i use a 12 inch shock and have 17 inches travel, and the duel rate works great. 500 over 500 seams sort of strange, you might as well just run a single rate coil. because duel rate coils are supposed to have a main spring (bottom, longer, higher rate), and a tender spring, (top, shorter, lower rate). that is the hole purpose of using duel rate coils. anyway, as for the downy leafs, i had a pair on my truck a while back. They worked a lot better than stock, but they arent nationals thats for sure. but you cant beat the price. i heard Baja Concepts is offering some toyota 62 inch leafs for like 325 dollors, which is like half price. and they are the best leafs you can get for a yota. just something to look into. hope this helped.
BUILD IT YOURSELF, BREAK IT YOURSELF, THEN BUILD IT YOURSELF AGAIN - PTD Off-Road Motorsports
P.S. A buddy of mine builds front ends for yotas at his fab shop, when hes doing it on a v6, he usually uses 2.0 shocks, because of the less room in the engine compartment. but his kits are pretty involved, so maybe you wont have a problem. hope it works out for ya.
drtdevil93
1,769
11
toyota class 7:
dual rates still have 2 different rates. if you have two 500 lb/in coils, the effective rate is 250 lb/in. once the slider hits the stop nut, then it goes to the 500 lb/in rate, giving it 2 rates.
erik
Well I sure like to know how that is? I mean if the primary and secondary are the same spring then why would it be any different than having one big spring? I understand that effective rate comes into play when you have two different rate springs. Maybe Dylan can spread some light on this..
Tony
sirhk100
2,797
678
It's a physics problem basically. If you take one 18" spring and compress it 8" the spring has obviously compressed 8". DUH!! If you take 2 9" springs that are the same rate as the single spring stack them so that they are 18" and compress them the same 8" each spring has only compressed a total of 4". This is a start of the explination and I'm sure that someone can explain it better. Basically though it has to do with the center part where they are stacked being able to move and that each spring is compressed only half the distance. Correct me if I'm wrong but if you're using a dual rate coilovers with say a 600lb and a 300lb spring and tested it on a machine that measured the resistance wouldn't you actually get a shock with three levels of resistance through the compression cycle. one at 300lb, another at 450lb, and then the final 600lb rate?
'99YZ400,
lifted golf cart
BradM
618
That only works if the springs are different lengths or if there is a mechanical limit set on the shock body to limit the travel of one spring. If the springs are the same size (diameter, wire diameter, number of coils, and free length) then the deflection in both springs will be equal.
There are other reasons for dual springs than a variable rate. On a shock with 12" of travel, there will be 26-28" of spring (a rough guess). Springs that long will likely be custom made or very hard to find in stock if they are available. Also, shorter springs have a reduced tendency to bow and rub on the shock body.
"The only source of knowledge is experience." - Albert Einstein
BradM
618
Khris, you are wrong on that one. If you stack a 300 lb/in spring and a 600 lb/in spring in series, the equivalent spring rate of the series combination is 200 lb/in. That applies until the softer spring reaches a mechanical limit stop or until it reaches a solid state (coil bind). Most coil springs have a rated maximum deflection which is about 80-85% of the total deflection because spring rates become non-linear in the initial 15% and final 15% of deflection. That also reduces the maximum stresses in the coils.
If you take the spring rate of the softer spring by itself (300 lb/in) and multiply if by the recommended maximum deflection of that spring, that will give you the location of the mechanical limit stop (don't forget to account for preload). At that point, if the 300 lb/in spring reaches a mechanical limit stop, all remaining load will be applied to the 600 lb/in spring. Therefore your spring rate will change from 200 lb/in to 600 lb/in at that point.
Effective spring rates for springs in series can be calculated the same as resistors in parallel. For two springs: (S1 * S2) / (S1 S2) will work. For more than two springs: 1/Se = 1/S1 1/S2 1/Sn where Se is the effective spring rate for all springs and n is the total number of springs.
"The only source of knowledge is experience." - Albert Einstein<P ID="edit"><FONT SIZE=-1>Edited by BradM on 10/31/01 08:27 AM (server time).</FONT></P>
sirhk100
2,797
678
Thanks for the info, I wasn't quite sure I was right and I guess this time I wasn't. Thanks for the info!!
'99YZ400,
lifted golf cart
BradM is right, but I think his equation was missing a sign (S1*S2)/(S1+S2), You can go to Sway-A-Way web site and they have a couple of pages that give some spring rate selection info and the dual rate spring equations.
BradM
618
Actually, I had the plus signs in the equations and when I edited my post, they were dropped. Why is the John? For what ever reason, in the editing mode the symbols won't carry through.
The alternate series spring calculation is 1/(effective rate) equals 1/(rate of spring 1) plus 1/(rate of spring 2) plus 1/(every other spring rate).
Brad
<P ID="edit"><FONT SIZE=-1>Edited by BradM on 10/31/01 10:01 AM (server time).</FONT></P>
fishd00d
What A Joke
15,548
5,709
Hmm, well I got an F in algebra heh. But I will take what you guys said into account if I can understand it :) I'm going to pickup the springs here in a second.
Man this is such a tight fit. I am talking about centimeters of clearence heh. Anyone know if anyone elce has put coilovers on a V6 Yota? If so anyone got any pics?
Go Big Or Go Home
If anyone is interested I have a spread sheet that gives the dual rate equivalent rates that reads like a multiplication table, it easier than getting out your calculator.
Ryno
1,230
33
Fish-
How big are the hoops? I am assuming you are bailing the t-bars? I know your yota weighs about 300 pounds less than my chevy, so I'm looking for spring rates here folks. I wanna do the same coilover conversion, and have a nice set of arms and stub axles built, ot the axles built off the stock axles. Anyone seen this or done it?
Ryno
PS-How much room would going to 2.0 shocks give you?
fishd00d
What A Joke
15,548
5,709
WHOOO! I got the drivers side (hard side) hoop done! Its all bent and ready to weld in. I am not sure how big the hoops are. They are as high as I could go without hitting the airbox on the drivers side. Yes I am ditching the tortion bars. I know nothing about spring rates so I am just going by what Baja Concepts recommended. 500 over 500. I know its not dual rate and if it dosent work good they said they will exchange them for different rates. HOPEFULLY I can have the truck finished and back on the road tomorrow for the desert this weekend!
Go Big Or Go Home
fishd00d
What A Joke
15,548
5,709
Yay! Drivers side is welded in place!
Go Big Or Go Home
John Bitting
Administrator
11,951
2,560
Fish get off the internet and finish that thing so we can see it sitting on the ground. I want to see the shocks bolted in place... :)
fishd00d
What A Joke
15,548
5,709
Wel I have one problem. The welder just broke! The wheel that feeds the wire wont turn anymore!!! FIGURES! So I have to run to home depot and buy the best one they have and then return it tomorrow :) Any suggestions? :) I am thinking the most expensive one.
Go Big Or Go Home
Yeah fish get to work! And stop calling me about the welder being broken. Just get your butt to Home Depot and buy a new one! LOL!!!!
Tony
fishd00d
What A Joke
15,548
5,709
Here ya go John!
I need a fricking car to get to Home Depot! Arrr. I'm thinking about riding my bike then taking the shopping cart home cause there is no way I am carring a welder home on my bike!
Go Big Or Go Home
