quick disconnect for light bar
prerun15
Nov 14, 2007
68
9
simi valley
What is the best way to build a quick connect/disconnect for your light bar? Any pics?
. Anypics of a light rack on a 5-1600 or class 5? THANKS.
06dak287
Feb 3, 2009
249
Henderson, Nevada
you mean electrical connections? or hardware?
i would think if you had those heims rods on the sides that hold the rack upright. use those beefy bobby pin looking things with some pins instead of bolts?
DSRacing
Mini Metal MOD
Jan 21, 2003
3,488
423
We used tube clamps for our light bar.
diirk
Jun 9, 2007
599
12
Lancaster, CA
www.durkee-racing.com
Not sure what you're looking for.
These might work for you for mounting to the cage.
or use standard taps and some ball-lock pins for attachment.
diirk
Jun 9, 2007
599
12
Lancaster, CA
Nice pic Baja Stu. I've been trying to decide I want to set up mine, and this is definately a candidate.
De Ranged
Jul 7, 2009
15
New Zealand
Just a suggestion if your going to go with a "tube in a tube" holder, why not weld the smaller inner tube to the frame.... the reason I say this is where I'm from we have alot of mud
If you are trying to fit the light bar in marginal light :rolleyes:things like this normally only get fitted when its already dark enough that its a stuggle to find the pin when you drop it.... add to this that small stone or some sand thats stuck at the bottom of the tube when you trying to fit your light bar in there and get it low enough to put the pin through
But if the bar fits over the locating tube.... hopefully no drama's lol
Cheers Reece
darinz
Dec 27, 2008
40
New Zealand
I have mine setup to hold on with hose clamps. All that has been done is a piece of tube is cut in half and that sits over the rollcage. Then I have hose clamp front and rear on each side to hold it on. Simple easy and big hose clamps have an amazing amount of strength!
ChromolyKid
Mar 15, 2009
1,095
96
CA
www.youtube.com
Small tube in a big tube with a pull pin. Cheap and easy.
This is off topic, but your avatar just made me blow on my screen. I was about to flick it then i realized... hehe :eek:
