Quick Shock Question
1992f150
Dec 23, 2001
373
Azusa, Shame of the foothills
www.y2khai.com
Im rebuilding my shocks, got them all torn apart (except valving assembly attached to the shaft) My question is, I always hear replace the seals etc..., are the seals just the O rings or what?
Oh, also im revalving these (dual front shock application) Is there a way to tell what the numerical valving is on a shock by looking at it? ie 175/70? Im pretty sure the previous owner never revalved any of the shocks, and just dropped the psi to 110 on the extra shock, which made the things leak.
Thanks.
Azusa: shame of the foothills
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
typically you need to measure the thickness and diameter of the shims. then refer to the shock manufactures chart for their referance number.
yeh, the seals on the shaft especially. also the seal on the piston wears out too. usually these last pretty long though. i replaced all mine once a year, just for good measure.
"to be successful, you must first learn to disagree without being disagreeable."
martininsocal
Apr 10, 2001
22,828
Big Bear,Ca.
It depends on the shocks you have. some use a seal and a wiper and some use double o-rings. At minimum, you should replace the shaft wipers and seals and the piston wear band.
Martin
If your gonna go, go BIG
1992f150
Dec 23, 2001
373
www.y2khai.com
anyway here is what i got to work with
hoeker
Oct 9, 2002
2,004
101
holland, MI
www.rosshoek.com
the wiper seals on the shaft go first. orings are really,really,really cheap just replace them all. fox swore i was replacing the DU seal on the piston way more than i needed at once a year racing. those are also 7 or 8 bucks each, not too bad if you only need a few, but my truck had 16 shocks!! if they aren't that old, run it.
