Race Radio Help
that_slow_5.3
13
Hey guys, i just got a rugged rm-60, their 60 watt VHF radio, i got everything installed how they said, grounded to my steel roof, no coiled coax cable, wired directly to the battery via their harness. I printed out a antenna cut chart and the antenna supplied is right in range for the 150-170 MHZ. My question is, do I need to tune it or dial it in any before i use it? I'm just not familiar and defiantly don't want to ruin the new radio.
Thanks
mgobaja
3,374
594
You should be fine using it. BUT - if you get a chance to take the car with the gear installed to an event that Rugged or PCI is at, and ask them to tune the antenna at that time, that will help it to perform at its best possible.
SMS81
234
256
I’m pretty sure rugged has some tech support in so cal, I would give them a call and they can help tune it. I got the same radio this year and have been really impressed. No BS, at the 1000 this year I was able to talk and listen to score ops from Yuma AZ!!
johndjmix
958
872
The antenna is what you need to tune. You can do it yourself, or have them do it. Basiclly you will connect a SWR meter and put the radio on your center frequency, transmit, and tune by cutting the antenna down little by little.
Every antenna on every vehicle tunes differently. Best to do it in the middle of a large open area with no metal objects around. Rugged has a pretty good video on how to do it.
If you have fun with it go get your HAM license. Super fun and you will know EVERYTHING about how to make your radio work the best!
--John
baja_racer
626
293
Agreed, on-site tuning with Rugged is best. Note, you can have the baddest radio out there, but make sure who's listening is tuned also.
