race ready 9 car for $5k
Anthemracer
Apr 17, 2008
24
Anthem, AZ
Too many toys and not enough room so this car needs a new home.
Asking $5,000 Please reply via this post or private message
Engine is new, 1 short race only (firebird), very well built race engine by Jeff Knupp.
Everything works and is ready to go!
Tons of spare parts/wheels included.
Check out DGP's photos from Firebird
Engine specs:
Kennedy Pressure plate
85.5 Forged Piston set
Total seal 2nd groove ring set
Aluminum engine pulley for machine in seal
Full flow oil pump cover
Air intake screen
Push rod tube protectors
Engine sand seal
Straight cut cam gear set
Chromoly valve spring retainers
Solid rocker arm shaft kit
Swivel feet valve adjuster screws
Double trust cam bearing set
31mm racing lifters
Web Cam
26mm oil pump, plugged for full flow
HD Flywheel nut and washer
Racing single valve spring set
Stainless intake and exhaust valves
Windage tray
Windage tube push rod tubes
8mm head stud kit
Engine case, full flow and sand seal cut
Crank 8 dowell, balance
Flywheel, surface, lighten and 8 dowell
I can't get a picture to embed but here is a link to one.
http://anthemaz.info/9/DSCN0243a.jpg
Anthemracer
Apr 17, 2008
24
Anthem, AZ
some more info;
PCI race radio
22 gallon fuel cel
5 point crow harness
air pump
Transaxle Engineering transmission
Fox Racing 2.0 shocks - front
Racerunner 2.5 shocks - rear with limit straps
MSD 6ALN ignition box with matching MSD racing distributor and plug wires
Beard Seat
Removable light bar with 2 HID lights never used (bar holds 4 lights)
