solid works is a great program, not sure how it interfaces with tube, can't see why it'd be a problem, all tubing is a simple extrusion, easy for any solid modeler. i had several guys offer to help with my new chassis on Pro-engineer, swore it'd be a piece of cake, didn't take anyone up on it because it was easier to do it myself on mastercam. mastercam is primarily a machining software, but has surfacing and solids. i am not familiar with the solids, so i surfaced every tube on the truck to figure out bends and miter cuts. this was probably very time consuming compared to a solids package, but because i know the program better than most, it was the proper tool for the job.
the point is simple, use what you know. there are literally hundreds of packages that can aid you in the chassis design. all of the best fabricators i know don't know how to touch a PC. we will see this change, but for now that's the way it is. they go from experience and common sense.
if you don't know jack about CAD, take a class at your local junior college, and buy the student version of whatever they teach (hopefully Pro-E or solidworks). a semester or two and your on your way to designing some killer stuff. start with simple parts and work your way up to the entire chassis. you'll be amazed what you can do, that some of the best fabricators in the country have to hire out.
Autocad is typically over rated and under powered. autocad has been triving on their name and uneducated buisiness owners for years, avoid it if possible. the first out is not always the best.
ntsqd--- was that a faro arm?? never used on but they are great for alot of things. most cup teams have one now. not super high tolerance, but lots closer than a straight edge and level.
"to be successful, you must first learn to disagree without being disagreeable."
