Klapper431
Looking for some advice/help with my current build..
I have a ranger with a full threat equal length beam kit. Just made the switch from unequal length. Did the new beam kit, dual swing steer, new engine cage and shocks. After doing all this work for the switch and setting the truck down on its own weight I have a ride height and camber issue. I had 300 over 400 spring rate with zero preload in the springs and the fender line was sitting 5 feet in the air. Being zero preload in the springs I couldn’t back the preload nut off any to lower the ride height because the springs would be loose at droop. So I then switched to 250 pound springs top and bottom just to see what it did for the height. It did help but still not enough and again zero preload. Rolled the truck to try and get it to settle and even drove it. The night time picture is after driving the truck and not much changes. So I’m stuck with not knowing what my next best option is to try… I’m all ears open to learn something! Thank you.
