Prerunin554
- 639
- 41
I have a 96 ranger that i am currently caging it front to rear. I decided to pull the ABS module (4 wheel ABS) since i will be re-plumbing the front brakes anyway. I spent countless hours in the Ford repair manuals and EVTM's, but cannot find the info i need. On the master cylinder, the front line coming out is for the front brakes, and rear is for the rear, correct? Also, should me pulling this module interfere with any of the other modules (as the system is mutiplexed) other than setting an ABS code and triggering the light on the instrument cluster? I will be looking into the wiring diagrams tonight to verify this, but help is always appreciated. Thanks in advance-
BTW, 96 ranger 4.0 manual trans power everything, reusing the stock dash
