RAPTOR WOES
mustafa
My 02 raptor will only run with the choke on. It is completely stock with the exception of a Uni air filter. I changed
the gas, plug, made sure the air filter was installed properly etc...and I can't get it to run correctly. It misses really
bad with the choke off. Any suggestions would be greatly appreciated.
desertratt
sounds likeits sucking air from some where
ACID_RAIN28
The pilot jet is cloged, remove the carb and clean, clean, clean. You have to do an autopsy on the carb inorder to get it cleaned. If you half arss it, you will just take it off again and try again. I have had this problem with my DRZ.
mustafa
thanks! I will try and clean the carbs this weekend.
