Rear Bucking
slvrbullet
188
74
Hello all,
I wanted to see if you anyone could help me with and issue I'm having with my car. Whenever I hit a single large bump the rear kicks up, in the whoops though it works great. The front seems to soak up these hits just fine. Is this more of a spring issue or is this a valving issue?
Car Specs:
Short Wheel base
Rear Engine
2.5 Fox C/O's with bottom out control on the firmest setting (any softer and it bucks more)
slvrbullet
188
74
Shocks are FOX 2.5 Podium QS3 with bottom out control. It’s on the Textron Wildcat xx UTV.
Front preload is 1.92” with the cross over engaging at 1.2”
Rear preload is 3.72” with the cross over engaging at 1.31”
I think I will need to raise the rear about 1.5” and the front about 1” to get the advertised 14” of ground clearance.
