Rear bypass bump angle
shrive81
Jan 5, 2013
119
82
beaumont, ca
Hey gents,
so working on building my car and have to do upper shock mounts for the car. Had a question for the smarter gents here then me. I need to set bypass position at full bump and understand I want to get it as close to 90 degrees as possible. My question is what do I base that off of.
1. From front pivot point to center of hub then go 90 degrees off that and lean forward if i need extra down travel
2. From front pivot to center of bottom bolt on Bypass.
I appreciate the help and will attach a photo to help
shrive81
Jan 5, 2013
119
82
beaumont, ca
I am thinking about moving the arm mounts (lower mounts) back father on the arm to help with room on shock tower.. the shock is not in position it is just resting there for reference
Justin.M
Jan 15, 2022
Poway, CA
Basically draw a line from your pivot point and your hub center and that's what you want it to be 90 to!
Jan 17, 2019
14,278
9,005
sandiego
am i getting the 90 degrees thing right?,at full bump the 90° is measured from the straight line from pivot through the shock mount eye, correct?
Jan 17, 2019
14,278
9,005
sandiego
close^but i just look at Ribi & figure Anything will work😬
