rear shock mount location???
singlehanded
Jun 3, 2001
1,584
Placentia,Orange County
I am mounting my rear shock to a cage. I not exactly sure how to figure out how high I should mount them. I have 10" from axel top to middle of bumpstop and I figured mounting them 13" forward at a 25 degree angle the shaft would need to be 11" minimun out. It is a 16" travel shock and that would only give me 5-6 of down travel. Is that right or can someone explain how to find where shock should be mounted?
local
Jun 18, 2001
297
Gimme your email and I will send you over a spreadsheet program I made to help you out.
singlehanded
Jun 3, 2001
1,584
I not gonna do that no point. I am just figuring so the shock over compress. I will limit the down travel once mounted.
local
Sep 17, 2001
Here
For up travel I use metal to metal where the bumpstop is, and add ~1/2" more shock stroke which should cover the housing twisting relative to the frame. If the shocks are more inboard than outboard increase that 1/2" number to something comfortable.
