RE: "I figured it held up both motos so you guys would stay with the winning combination."
Hey, Jeff! Yeah, if it works don't fix it, right? Winning does not suck. We have had such bad luck this year, we haven't had time to do the little things we'd normally like to. We've had to pull the motor after 6 of the 7 races we did this year. We're also running a "new" C4 trans that unfortunately only gets 1st & 2nd gear.
Since it did so well last time, we decided to get rid of the desert setup by putting in lower, lighter springs, adding a sway bar, and adding more - camber. Should be a blast!
RE: "We dropped the inner brake pad on both front brakes..."
So THAT'S how you ended up parked on top of his rolled truck! When we saw that coming out of the turn, we just figured the two trucks were in heat! HAHAHAHA
RE: "...do they usually run us with the 7 open guys?"
We'd LOVE to have you run with us, because it's way funner with a lot of trucks. (and more points & $ for the winner) If there's less than 3, then yes, they usually combine those vehicles with the other class. My only chance for the championship now is to WIN, and then have as many trucks as possible beat Patty Hayos. Oh, and then she still probably has to DNF. Go ahead and lean on her! You and Fred both have my blessing. I wouldn't take her out to win, but you certainly can!!
See you there... Oh, and to stay on topic: Tim, the offer still stands if you want a short course ride closer to home. (See Pic)
Billy
