Hi i am looking to run a reverse intake manifold on my ls2 what problems should i expect? what is the solution to the valley plate and oil pressure sender?
We always just chop the little stand off where the oil psi sender goes. Then weld it closed. Nothing else needs to be modified. Just make sure you don't switch your vacuum line around. If you need another spot to put your oil psi sending unit, right above the oil filter is where I would go.
