Roll Cage
Motorider
May 21, 2001
346
San Diego
Can anyone help me with how you install the rear window, I know it's not glass, but to you have it setup before you weld the tubes in , then just manuver it into place, or is there some other way?
Thanks
SpareChangeRacng
Nov 30, 2001
606
Balboa Island
If you look closely you'll see that about a 3" square or so aove where the tube comes through the window is a diff. color. When I have seen lexan windows and cages set up like this, they typically have a U cut out of the window so that it can be slid up from under the cage and set in place. They then use 2 pieces (what I believe are the off colored ones in your pic) to fill the gap up top.
Clear as mud w/ that explanation huh? Steve
toyotaguy
Mar 11, 2003
63
orange county, ca
whats up with the kings mounted the way they are. Are some people just trying to be different or is it proven to be better than the conventional straight up and down
elcaprerunner
Oct 13, 2002
951
San Dimas, CA
That is the same cantiliever setup as on Baldwin's Trophy Truck, also on Dave Winner's (sp?) tube chassis Fabtech prerunner, both designed by Brian Kudela.
sirhk100
Aug 27, 2001
2,797
678
las vegas, Nv
Where did you find the photos of CST's truck... I saw that thing at Sema and wanted some photos but my camera died.... Anyone got any?
FordFreak
Jun 26, 2002
65
Orange, CA
they have them on their website which is under construction but the pics page has some nice stuff and also their projects page I think.
In_the_works
Sep 19, 2002
305
none
I've heard that that truck is pretty much all show and no go, the cantilever binds pretty bad when going through the stroke, and it (obvously) doesn't see much off road use. Can someone confirm/deny this?
sirhk100
Aug 27, 2001
2,797
678
las vegas, Nv
When I saw it at SEMA it definately wasn't off road built. It had a bunch of CNC billit stuff all over it to show their capabilities. If I remember right CNC alum upper and lower control arms. CNC aluminum trailing arms for the cantilever. Just lots of shiny stuff that looked machined very thin and small. Delicate would be the word...
RacerX
May 21, 2001
1,094
61
Fontana,CA
That is correct. The wishbone hit the driveshaft at full bump and the cantaliever(sp?) arm hit the cage work when cycled. Thats from what I heard
CRAIG_HALL
Oct 28, 2002
2,529
584
San Diego
www.halldesigns.com
The truck was built for the S.E.M.A. show thats why all the polished aluminum arms.I talked to Chris last week and they have already built new upper and lower arm to replace the aluminum ones,not that they broke,but the lower wouldn't last, the upper was probably marginal.He said he'd possibly like to run an MDR race with it only because his son is into the whole truck scene. Chris himself only wants to do it for his son. He says he's over the race scene,he's put in his time.
I do know he is getting ready to lift his personal H.D. (long travel coil-over) so I'm guessing he might need his regular cab truck back to drive around. I waiting for him to drive up to my shop in it !
<font color="red"> CST-link </font color>
