Rugged Helmets w/ PCI??
mattb
Jun 8, 2004
1,048
274
Poway, CA
Are Rugged and PCI helmets wired the same so that they can work with each others radios and intercoms? I just plugged my Rugged wired helmets into my PCI system and have no intercoms working, unless I use the Push to Talk buttons. Otherwise, we cannot hear each other.
THX!
M4BoomStick
Feb 13, 2017
32
26
CA
If you have a TRAX intercom ( grey/silver face plate) it will not work with Rugged helmets because TRAX is stereo and takes a 5 pin connector . You can get an adapter through. You can also look at the color at the ends of the intercom cables (female) and/or helmet wiring (ma
MONO and work together with no adapter
Rugged ( blue connector )
PCI Mono ( black connector )
Stereo
PCI TRAX ( grey connector)
Curve ball- if it’s a 4 pin connector, there are also Other pin outs it could be
