customcreationsllc
- 15
- 1
My goal is to be able to run everything upside down without consequences.
Rock Crawling you're eventually going to roll and its worth hitting the gas to get it to roll back over. But that cannot be good running the engine with no Oil Pressure.
So I was thinking.
If I get a 3 or 4 stage dry sump can I plumb one or two to the Valve cover?
So I'll get oil even upside down.
Question is will the stage plumbed to the valve cover burn up since it will hardly ever see oil?
Will the dry sump plumbed to the top work for sucking fumes out of my engine so no PCV valve for a sealed engine block.
I'll just have to set up a dual vent on the dry sump oil tank.
One vents the top and one vents the bottom. So it will loose a little bit of oil whatever is in the line.
It might burn a little oil blow with the oil sitting on the pistons.
But it should get flung around and back to the valve cover.
My biggest worry is burning up the Dry sump pump.
I also thought about maybe Splitting the lines, a little line from the oil pan just enough the lube to the pump.
Any thoughts?
Ecotec Motor running off Propane.
Coolant naturally self sealed.
Standard Trans/ manual T-case
Power steering accumulator/closed loop system, I know people who have done it before.
So I was thinking.
Any thoughts?
